1977 Toyota Celica No fire to my in tank fuel pump.
1977 TOYOTA CELICA
146,000 MILES • 4 CYL • 2WD • AUTOMATIC
WILLYBGORILLA
I am not getting any fire to my fuel pump. Any suggestions? Help? It has been setting up several years. Have cleaned tank and replaced fuel pump with a new one. Now I find I have no charge to the new one.
Apr 29, 2009 at 9:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Inspect fuses and relays, let me know.
Apr 29, 2009 at 9:37 AM
WILLYBGORILLA
Where would I find those? Does the fuel pump have a fuse in the fuse box? Where are the relays?
Apr 29, 2009 at 10:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
I looked over the fuse legend and there seems to be no fuse for the pump itself. Check the fusible link which is located in-line at the positive battery terminal. Unfortunately none of my sources can lead me directly to the fuel pump relay location, however I have been able to dig up the wiring schematics. There is indeed a fuel pump relay as well as a fuel cut off solenoid attached to the fuel pump wiring. You may have to trace the yellow wire from the pump assembly to find the relay and solenoid.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_498.jpg
Thanks for using 2CarPros.com!
Apr 29, 2009 at 10:50 AM
