1998 Toyota Carina Reverse gear makes clicking noise
1998 TOYOTA CARINA
180,000 MILES • 4 CYL • FWD • AUTOMATIC
NAREFEEN2003
My everything of the transmission is perfectly alright except when i put the gear on reverse.there is a clunk when i m putting the gear one reverse.thats the only problem.the reverse gear shifts instantly with that sound.is there any problem with that?
Nov 5, 2010 at 2:03 AM
KHLOW2008
  • 41,814 POSTS
Hi narefeen2003,
That would depend on where the noise is coming from. It could be the engine mounts or drive trains having excessive clearances.
Nov 5, 2010 at 4:43 AM
NAREFEEN2003
[quote:e7221b303d="KHLow2008"]Hi narefeen2003,
That would depend on where the noise is coming from. It could be the engine mounts or drive trains having excessive clearances.[/quote:e7221b303d]
Nov 5, 2010 at 5:42 AM
NAREFEEN2003
i think its from the transmission.....it occurs more clearly when transmission is hot....but there is no problem in shifting
Nov 5, 2010 at 5:44 AM
KHLOW2008
  • 41,814 POSTS
With the age and mileage on the vehicle, some wear would be eminent and if the fluids have not been replaced for a long tme, check the level and condition and if necessary, replace it.
If it is from within the trans, it could be getting old and it is an indication it is on its way out. There is nothing you can do about it except use until it fails, unless you wish to have it rebuilt or replaced.
Nov 5, 2010 at 6:00 AM
