1997 Toyota Camry Won't Move in Gear
STICK126
I have a 97 Camry with 105,000 miles on it. I have had my car looked over at several places recently when getting minor maintenance and they all said it was in great shape. Then I took it in for an oil change and had everything looked over again and all was fine. I get the car back and I noticed the gear shifter slid easy when just the day before it shifted just fine. I drove to work and when I went to get in it to go home, and put it in drive nothing happened nor any other gears. It revs fine, but goes nowhere. I have not had any transmission problems at all nor anything that would indicate a problem. I am hoping for the best but preparing for the worst.
May 30, 2006 at 2:22 PM
LOSONE
  • 1,616 POSTS
You now have tranny problems.
Have you checked the tranny oil level?? There is a scam around here where lube shops drain the tarnny oil and have a deal with a repair shop. I hope it isn't true in your area.
Good luck
May 31, 2006 at 9:43 AM
Suggested Repair
Check the transmission fluid level. The sudden no-drive condition after an oil change may mean the fluid was drained by mistake.
Conversation Summary
The owner of a 1997 Toyota Camry with 105,000 miles says the shifter suddenly moved easily and the car would not move in any gear after an oil change, although the engine revved normally. There were no earlier transmission symptoms. The expert advises checking the transmission fluid level and mentions a possible shop practice of draining that fluid.
