1999 Toyota Camry Engine Rattle
WATER2224
I purchased a used 1999 Toyota Camry CE (4 cyl engine with 170,000 mi) about 12 months ago. In January, I took it to mechanic for an oil leak and a rattling noice from the engine. Unfortunately, we learned that the timing belt had never been replaced. The mechanic replaced the belt and several gaskets, but the rattling sound from the engine remained. His suggestion was to completely replace the engine. Recently, the noise from the engine is very loud. Before I take it back in, any input on the likely problem and suggestions on a solution? Thanks.
Aug 27, 2007 at 6:49 AM
  • 31,937 POSTS
Hi there,
Engine rattles can be caused by a number of items, but the the common denomator is usually low oil pressure. I would have the oil & filter changed, maybe use an engine oil flush first, have the oil pressure tested to see if it is still in specs. if oil pressure is too low engine change or re build time. Check the valve clearances, but as they are shimmed these normaly dont rattle with age, but there may be an oil supply issue to the top end. With out hearing the noise it is a bit hard to suggest what to to next, only make sure that all the basic 's are ok, before making any desicision that will cost dollars.
Mark (mhpautos)
Aug 27, 2007 at 11:13 AM
Suggested Repair
Change the oil and filter, consider an engine oil flush, and test oil pressure. If pressure is low, plan an engine rebuild or replacement. Also check valve clearances and oil supply to the top end before committing to a costly repair.
Conversation Summary
The owner of a 1999 Toyota Camry with 170,000 miles reported an oil leak and engine rattle. The timing belt and several gaskets were replaced, but the rattle remained and became very loud; a mechanic suggested replacing the engine. The expert advised checking oil pressure, oil and filter service, valve clearances, and top-end oil supply before deciding on a rebuild or replacement.
