timing belt/water pump
BFSTAUFF
On routine maintenance of my 2000 camry 4 cyl with less than 90,000 miles, the shop suggested replacing the timing belt as a preventive measure. Shouldn't the water pump also be replaced as a preventive measure when the timing belt is being replaced? Thank you.
Jun 10, 2007 at 4:23 PM
  • 75,988 POSTS
[quote:f2b6baf9de="bfstauff"]On routine maintenance of my 2000 camry 4 cyl with less than 90,000 miles, the shop suggested replacing the timing belt as a preventive measure. Shouldn't the water pump also be replaced as a preventive measure when the timing belt is being replaced? Thank you.[/quote:f2b6baf9de]
I would change both,am in there might as well do it for the love of preventive maintenance.
Jun 10, 2007 at 11:55 PM
