Thermostate or Water Pump?
LYNN75150
Every morning when I get into the car(1993 Toyota Camry Wagon 6 cyl) there is a puddle of anitfreeze under the car. I have changed the thermostate in the car and it is still doing it. I put antifeeze and water in the car ever morning. The car runs fine and doesnt over heat during the day this just happens at night. Can it be the water pump or something else that is causing this to happen.
Feb 9, 2007 at 1:25 AM
  • 75,988 POSTS
Replace Radiator Cap
Feb 9, 2007 at 7:05 AM
LYNN75150
[quote:45858b545b="rasmataz"]Replace Radiator Cap[/quote:45858b545b]
Even if the radiator cap still looks good?
Feb 9, 2007 at 8:56 AM
  • 75,988 POSTS
Even if its brand new-manufacture defects. If its the water pump you'll find out in a heart beat.
Try flushing out the cooling system-also could be a partial clogged Rad. and could be a thermostat again.
Or an overfilled reservoir bottle-you should have the cooling system pressure tested to rule out a combustion leakage-meaning blown H/gasket/Crack head abd block
Feb 9, 2007 at 9:13 AM
UTS
  • 8 POSTS
This coolant could be leaking from many places.
With the car at operating temperature, check closely for leaks from all hoses,radiator,water pump etc.
A water pump can leak, and a thermostat housing can leak, but a fault with the thermostat itself won't cause a leak unless it causes major over heating first.
Feb 10, 2007 at 6:55 PM
LOSTINMARS
  • 222 POSTS
[quote:016873e625="lynn75150"]Can it be the water pump or something else that is causing this to happen.[/quote:016873e625]
yes of course it could be the pump or "SOMETHING ELSE" :roll:
there is no way anyone here can tell you what's wrong. you have a coolant leak and the only way to find it is to have someone actually look at the car.
Feb 11, 2007 at 10:59 PM
  • 75,988 POSTS
When you see the puddle green stuff look between the transmission and engine where it meets if its there a freeze plug is leaking on the engine.
Do the pressure test and observe the reading a quick leakdown will tell you something-whether your cooling system is sealed.
Feb 12, 2007 at 5:51 AM
