Stutter problem when accelerating '93 Camry V6
JCANNON2
  • 6 POSTS
whenever i start accelerating the car seems to stutter unitl i go over a certain rpms. b/c of this the car died on me while stopped. also i idle to low, it dips below 1000 every now and then. the stutter problem i was told was either the spark plugs or the spark plug wires.
Nov 12, 2007 at 4:01 PM
  • 31,937 POSTS
Hi there,
If the car has not had a tune up for some time, get that sorted first. change Air & Fuel, filters, replace spark plugs and ignition leads. To replace the rear spark plugs the plenum chamber must be removed, this may be beyond your capabilities. These rear spark plugs are normally Iridium and don't need to be replaced for 100,000 Km. (60,000 MLS) front plugs are standard. The ignition leads are not cheap so be sure that they are faulty before replacing. A work shop will be able to read the Kva (voltage ) and check resistance to see if they are OK. also get a ecu fault code read out this will help determine and faults in the engine management system.
Good luck
Mark (mhpautos)
Nov 14, 2007 at 1:43 PM
JCANNON2
  • 6 POSTS
[quote:37f50d63f3="jcannon2"]whenever i start accelerating the car seems to stutter unitl i go over a certain rpms. b/c of this the car died on me while stopped. also i idle to low, it dips below 1000 every now and then. the stutter problem i was told was either the spark plugs or the spark plug wires.[/quote:37f50d63f3]
update!
I had a tune up and that did not solve the problem, im guessing its a computer problem. anyway i dont think shelling out 65 bucks at theToyota headquarters for a test is gonna help. i was told they wont tell me the exact problem, only what needs to be replaced.
Nov 16, 2007 at 5:43 AM
  • 75,988 POSTS
If you're in the United States go to autozone and get read for free and comeback with the OBD2 code/s and report your findings to Mr. mhpautos
Nov 16, 2007 at 9:04 AM
JCANNON2
  • 6 POSTS
[quote:4aeb6afd12="rasmataz"]If you're in the United States go to autozone and get read for free and comeback with the OBD2 code/s and report your findings to Mr. mhpautos[/quote:4aeb6afd12]
the only problem is that Autozone's cut off year for this test is 1996. any year before they dont do.
Nov 16, 2007 at 12:54 PM
  • 75,988 POSTS
Okay I misque this one thought it was 98
Find the diagnostic connector upfront jumper TE-1 to E-1 turn key On count the flash X XX X XX X XX
means code 12
Nov 16, 2007 at 5:01 PM
JCANNON2
  • 6 POSTS
[quote:f3160bff99="rasmataz"]Okay I misque this one thought it was 98
means code 12[/quote:f3160bff99]
i dont get it, how do i check it myself. i looked up the code 12 and it says Fuel Pump Relay Circuit
Nov 16, 2007 at 5:07 PM
  • 75,988 POSTS
I just use 12 for an example. its gonna flash then its gonna flash flash
BTW where did you came up code 12 being the fuel pump relay look below
Read the flashes and comback with it. see below for your codes
Diagnostic Trouble Codes - 1993
Toyota
12 Engine RPM Signal.
13 Engine RPM Signal.
14 Ignition Signal.
16 ECT Control Signal.
21 Oxygen Sensor (OS) Signal.
22 Water Temperature Sensor (THW) Signal.
24 Intake Air Temperature Sensor (THA) Signal.
25 Air/Fuel ratio lean.
26 Air/Fuel ratio rich.
27 Sub-oxygen sensor signal.
28 Main Oxygen Sensor (OS) Signal.
31 Air Flow Meter Signal.
32 Air Flow Meter Signal.
41 Throttle Position Sensor (TPS).
42 Vehicle Speed Sensor (VSS) Signal.
43 Starter Circuit Signal.
51 Switch Condition Signal.
52 Knock Control Signal.
71 EGR system malfunction.
Nov 16, 2007 at 5:14 PM
JCANNON2
  • 6 POSTS
[quote:a538881e12="rasmataz"]I just use 12 for an example. its gonna flash then its gonna flash flash
Toyota
14 Ignition Signal.
71 EGR system malfunction.[/quote:a538881e12]
ok, so i count how many times all the X;s flash and that number determines the code? also i didnt understand by what u said about "Find the diagnostic connector upfront jumper TE-1 to E-1 turn key On count the flash X XX X XX X XX"
Nov 16, 2007 at 5:31 PM
  • 75,988 POSTS
You jump this terminals and with the key On, the CEL will start flashing. again 1st flash will indicate the first no. then it pauses then it will flash the 2nd digit no.
Note: it will flash 3 times for the same code. if there's more in it it will flash the next one.
Nov 17, 2007 at 7:23 AM
JCANNON2
  • 6 POSTS
[quote:2bde2ad058="rasmataz"]Find the diagnostic connector upfront jumper TE-1 to E-1 turn key On count the flash X XX X XX X XX"
Note: it will flash 3 times for the same code. if there's more in it it will flash the next one.[/quote:2bde2ad058]
ok i was told by someone at the toyota hq that i needed a new intake hose, and new trans and engine mounts. now what im guessing is that when i get the intake hose fixed then my mounts will stop shaking around. of course im gonna have to get those fixed.
Nov 23, 2007 at 1:43 PM
