rpm drops when accelerating
AURIR_
  • 5 POSTS
When i start the engine it's fine. As soon as i step on the gas pedal the engine kind of chokes - as if some of the pistons stopped working for some time. i have to very gently step on the gas pedal. This problem appeared after an accident; however, only the rear of my car was hit. The front/engine was intact. It is 2001 Toyota Camry LE V6
Jun 2, 2007 at 3:46 PM
  • 75,988 POSTS
[quote:fe37a3756f="aurir_"]When i start the engine it's fine. As soon as i step on the gas pedal the engine kind of chokes - as if some of the pistons stopped working for some time. i have to very gently step on the gas pedal. This problem appeared after an accident; however, only the rear of my car was hit. The front/engine was intact. It is 2001 Toyota Camry LE V6[/quote:fe37a3756f]
Get it scan for code/s and comeback with it. Or bench test the TPS and MAF sensors. Also check fuel pressure.
Jun 2, 2007 at 9:42 PM
AURIR_
  • 5 POSTS
The estimate done by a geico guy mentions something about pressure vent - which I believe has something to do with the fuel tank. Could damaged pressure vent affect fuel pressure? I'm totally car mechanics illiterate. What do you mean by codes? Hook up a car to the computer or something? How much does it costs?
Jun 3, 2007 at 5:51 AM
AURIR_
  • 5 POSTS
Ok, I was told the code is: random engine misfire. Could this be in any way connected to the accident that I mentioned earlier?
Jun 5, 2007 at 11:49 AM
  • 75,988 POSTS
[quote:7c91844c9a="aurir_"]Ok, I was told the code is: random engine misfire. Could this be in any way connected to the accident that I mentioned earlier?[/quote:7c91844c9a]
A Random Misfire code usually indicates a vacuum leak or bad gas
Jun 5, 2007 at 1:35 PM
AURIR_
  • 5 POSTS
Toyota dealer stated that I'll have to exchange spark plugs, wires, coil pack, distributor cap etc. They said they'll do it for $900 plus TAX.
Also they stated that the problem with the engine is not related to the accident which means that'll have to pay for it cause Geico will not cover it. The problems with the engine began right after the accident, the light came up a day or two after. However, only the back of the car was hit, so Geico and Toyota after thorough diagnosis concluded that it is a result of natural wear of all those items that they want me to exchange.
Questions;
1) Do they want me to exchange all of the ignition parts because they might not know what the problem really is?
2) What is the average price for such replacement
3) Is that something i could do on my own or is it too complicated?
4) What can i do to that dealership when after exchanging all of that stuff, the problem will persist?
Jun 7, 2007 at 12:02 PM
  • 75,988 POSTS
[quote:a8de4ca4c9="aurir_"]Toyota dealer stated that I'll have to exchange spark plugs, wires, coil pack, distributor cap etc. They said they'll do it for $900 plus TAX.
Questions;
4) What can i do to that dealership when after exchanging all of that stuff, the problem will persist?[/quote:a8de4ca4c9]
If you decide for the dealer to do the job-make sure all is well-when you leave.anything after that its your pocket.
Or buy the parts have someone cheaper to do it or pull a DIY thing.
Dunno what the Parts/Labor cost it varies.
Good Luck!
Jun 7, 2007 at 2:54 PM
KIN CHAN
  • 453 POSTS
Ras!!!!!!!.....u know me..i am a big advocate of professionalism but also carry a vendetta against rip off.
any ASE L1 certify independent can nail this problemfor a misfire...related or not may or maynot be related...make sure u find a shop with credential L1 ASE certified preferred with ASA and BBB member status
Jun 10, 2007 at 1:52 PM
AURIR_
  • 5 POSTS
A mechanic replaced 1 coil, sparkplugs, and wires. After that, rpms drop only when the engine idles, or I stand on the inersection waiting for the green light. When I accelerate there is no problem.
2 days after, the check engine light came up, and then Track off. According to some forums, EMC can be damaged. I'll try to see the mechanic tomorrow.
What do i need to do to nail Geico for it?
Jun 12, 2007 at 3:02 PM
KIN CHAN
  • 453 POSTS
i am here to diagnose and advice people on their best interest !!!!! ....
Jun 13, 2007 at 1:02 AM
