Removing broken plug extension on 95 camry
RONG
I have a 95 camry 2.2 and I broke the extension to the spark plug and the wire. How do I remove this plastic extension so I can replace the plug wire?
Dec 28, 2006 at 5:08 AM
GARFIELD
  • 197 POSTS
You may try a pair of long needle nose pliers, it may come off in pieces and can take some time to get to the metal inside to pull it off. You can try one of the cheap razor knives that have the small snap off blades to try and cut the rubber isolation off. I have had several of these in the past. Once you get the plug wires off make sure that you use dieelectric grease on the new plug wires before installling to prevent the wires from melting the the spark plugs like the one's that are on your car now. Good luck and hope this helps.
Gary
Dec 29, 2006 at 11:02 PM
