2005 Toyota Camry Rear Thumping Noise
CLASSYDEE
iI have a 2005 toyota camry..I purchased it used. I have had it for 3 months...and now I hear a thumping noise that is annoying. I hear it over bumps in the streets and it is not the tires. It sounds like my door is not shut all the way and its only on the right side. I have 48000 mile 4 cylinder, 2005 camry. Help. I took it in and they said nothing is wrong, but i know that sound is not right.
May 24, 2007 at 4:51 PM
SERVICE WRITER
  • 9,123 POSTS
Three people and a case of beer might be able to get you the answer. :wink:
Jounce the back end of the car aggressively and listen for the source. I'm sure you have ruled out the spare tire area and the trunk for anything moving around. Maybe exhaust, rear stabilzer links if equipped.
May 24, 2007 at 9:55 PM
Suggested Repair
Jounce the rear of the car and listen for the noise source. Confirm nothing is loose in the trunk or spare-tire area, then inspect the exhaust and rear stabilizer links if equipped.
Conversation Summary
The owner of a 2005 Toyota Camry reports a right-side rear thumping noise over bumps that sounds like a door not fully closed. A shop found nothing wrong. The reply suggests bouncing the rear to locate the noise, checking the trunk and spare area, and inspecting the exhaust and rear stabilizer links.
