Razamataz I tested the sensor
96REALWE
  • 39 POSTS
As Razamataz suggested I read the resistantance of the water temp. sensor, cold it reads 2.5 as it warms up it drops to 0.2 completely warm, I am trying to diagnose error code 22 on a 1987 toyota camry 108,000 miles, auto, 4cyl, if Raz is still there or anyone with an idea please help
Jul 15, 2007 at 3:23 AM
  • 75,988 POSTS
[quote:e0a3434e65="96realwe"]As Razamataz suggested I read the resistantance of the water temp. sensor, cold it reads 2.5 as it warms up it drops to 0.2 completely warm, I am trying to diagnose error code 22 on a 1987 toyota camry 108,000 miles, auto, 4cyl, if Raz is still there or anyone with an idea please help[/quote:e0a3434e65]
The sensor is good-now remove the EFI fuse for 10sec or better-place back in-start vehicle is it still there. Comeback and I'll give you more headaches. I'm here now
Jul 15, 2007 at 9:27 AM
96REALWE
  • 39 POSTS
Razmataz pulled fuse light went out than back on what next?
Jul 15, 2007 at 10:48 AM
  • 75,988 POSTS
[quote:bd11a7fe1c="96realwe"]Razmataz pulled fuse light went out than back on what next?[/quote:bd11a7fe1c]
Okay, now check the reference wire on the connector do you have 5volts.
Jul 15, 2007 at 10:57 AM
96REALWE
  • 39 POSTS
raz connected multimeter to both terminals both leads (red) and (blk) no voltage across connector
Jul 15, 2007 at 1:56 PM
  • 75,988 POSTS
[quote:22b1d6b921="96realwe"]raz connected multimeter to both terminals both leads (red) and (blk) no voltage across connector[/quote:22b1d6b921]
Did you turn key On-if still no voltage-troubleshoot the wire all the way to the PCM
Jul 15, 2007 at 2:11 PM
96REALWE
  • 39 POSTS
yes key on
Jul 15, 2007 at 2:26 PM
96REALWE
  • 39 POSTS
Raz where is the PCM looked under the hood, also checked for contnuwity with plugs and 6 in down on wire both are good to the harness
Jul 15, 2007 at 2:45 PM
