Having some front body work done on a 96 Toyota Camry SE coupe. Upper tie bar needed replacing or straightening due to being bent in front end collision. Upon inspection of work, there is space where the grooves in the radiator meet with the upper tie bar and they are offset a tiny bit.
How critical is fit between the upper tie bar and the radiator? Should I demand that the grooves fit perfectly or let this slide?
Thanks for any advise.
SPONSORED LINKS
Thursday, February 1st, 2007 AT 1:53 PM
