"Sloshing" sound in 03 Camry
MFDUNC
I have a 2003 Toyota Camry LE, 4cyl, 140,000 kms/84,000 miles. There is a sound that seems like water sloshing between the dash and the engine. I've read in other forums that this may be the result of the AC condensor drain hose being plugged. Could this be the cause? If so, how do I fix this? Thanks very much.
May 11, 2007 at 3:09 AM
ROADRUNNER118
  • 14 POSTS
run your car with the a/c running full blast on outside air. look under the hood on right cnter firewall around where your a/c lines go into the car. you sould see a small rubber hose appro.1/2 inch just sticking out.try sticking a q-tip or straw into the hole or you may even see water running out . also check to see any water dripping under car which will indicate where your drain line is. let car run a while to make sure you have sufficent condensation to drip out
May 13, 2007 at 2:38 AM
