Programmed radio stations do not stay when car is turned off
HUGHESOL
I have a 1998 Toyota Camry XLE with about 112,000 miles on it. It is a V6 and is in very good condition. The radio is from the factory and has had no repairs on it up to now. When I program the radio stations, they stay programmed as long as the car is on. Once I turn the car off the stations go away. When I turn the car back on, the stations are no longer programmed and the radio is always turned off (even though it was on when I turned the car off).
Can you help?
Nov 4, 2007 at 1:12 AM
FISHERMAN
  • 937 POSTS
[quote:e835e6f6a1="hughesol"]I have a 1998 Toyota Camry XLE with about 112,000 miles on it. It is a V6 and is in very good condition. The radio is from the factory and has had no repairs on it up to now. When I program the radio stations, they stay programmed as long as the car is on. Once I turn the car off the stations go away. When I turn the car back on, the stations are no longer programmed and the radio is always turned off (even though it was on when I turned the car off).
Can you help?[/quote:e835e6f6a1]
Hello !
Should be a fuse...
Start checking all of them, the memory its keep it with a live (+) feed to the radio at all time.
(the fuse box its under the dashboard)
let us know if you find it !
Good Luck!
Nov 4, 2007 at 1:22 AM
RICKY ROWLAND
  • 11 POSTS
My 99 toyota Camry radio doing same way as Hughesol what can it be Thanks
Jan 23, 2017 at 9:14 AM
CJ MEDEVAC
  • 11,000 POSTS
I looked up a '99 Camry radio wiring diagram in "Prodemand"
There are 2 diagrams
XXXXXXXXXXXXXXXXXXXXXXX
1st with amplifier
There are 3 fuses shown in it.
Radio 1 / 20 amp left side of engine compartment
Radio 2 / 7.5 amp behind dash, left of column
ECU-IG 15 amp behind dash, left of column
XXXXXXXXXXXXXXXXXXXXXXXXX
2nd without amplifier
The diagram differs,
However,
The fuses are the same as w/ amplifier and the amperage and locations are the same for the fuses.
Hope this helps
The Medic
Jan 23, 2017 at 10:24 AM
