1999 Toyota Camry, 120,000 miles. The drivers door power window goes all the way up or down if enough time has passed since its last operation. If you run it all the way down & try to go up immediately, it will only go for an inch or less, then you must wait at least several seconds & it will go up a bit more. The longer you wait, lets say a minute, the window will go up completely. The same thing happens only in reverse if the window was down & you roll it up. Also the drivers side power lock acts very similarly, and affects and is affected by the window operation. Can anyone give me a clue as to what might be causing this?
Mar 11, 2007 at 6:20 AM
