oil light
PEPENWE
Hello fellas
I am having a problem with my Toyota camry 1994, 95020 miles with 2.0 L that i bought 6 weeks ago. The oil light comes on whenever i make a complete stops at a stop signs/light and once i accerates or start moving again it goes off. Pls can tell me why this is happening. A mechanic wanted replace the oil pump, oil gasket and bearing for 1310. Is this the right move or is there something else i can do
Thanks
Jun 30, 2007 at 3:25 AM
JWALTH02
  • 180 POSTS
Have you had a chance to check the oil level? It could be low enough that the momentum caused by you stopping made the oil move forward making it come below the sensor showing low oil and on comes your light.
Jun 30, 2007 at 3:50 AM
PEPENWE
Yes i have checked the oil level and recently had it changed but the same thing keeps on happening
Jun 30, 2007 at 6:18 AM
