2000 Toyota Camry Oil Consumption
QDNUT
I'ts a 2000 Toyota Camry LE 80K miles, 4 cylinders 2.2L
I changed engine oil at 77K, when checking oil dip stick, notice oil was quite low
I found no leaks at all, the car run fine, no knocking, no blue smoke at all
Checked spark plug chambers I found some oil in the #1 spark plug chamber only (no oil in the other 3), no engine light, no oil light come on. Please help
1. what is wrong
2. can it be a DIY repair; if not what's the estimate cost.
Mar 6, 2007 at 4:02 AM
  • 75,988 POSTS
Its making it in the no.1 cyl. I would say its going thru the valve seal and being burn.
Mar 6, 2007 at 9:47 PM
JOEMECHANIC
  • 28 POSTS
Try using a bottle of Lucas oil stabilizer,this should help to significantly reduce the oil consumtion,I have used this product for many years with great success
Mar 12, 2007 at 8:35 PM
Suggested Repair
Oil in the No. 1 spark plug chamber points to a leaking valve seal allowing oil into that cylinder and being burned. As a lower-cost first step, try Lucas oil stabilizer to reduce consumption; if it continues, have the No. 1 valve seal inspected and replaced.
Conversation Summary
A 2000 Toyota Camry LE 2.2L with about 80,000 miles is using oil with no visible leaks, knocking, blue smoke, or warning lights. Oil was found only in the No. 1 spark plug chamber. One reply says oil is entering that cylinder through a valve seal and being burned. Another suggests Lucas oil stabilizer to reduce consumption.
