Oil change caused check engine light????
WTUSER
I have 1998 Toyota Camry LE and i usually get the oil change done at every 3500 miles regularly. When I got that done recently, the oil filter started leaking oil right after it came out of shop. I pointed that out and mechanic reinstalled the new filter, just by taking filled filter off and putting new filter on. He did attempt to take filter off while my car was running but obviously he couldn't because it was pressurized inside. Obviously, when he took the first filter out that he had installed with oil change, he said the seal was not even and it was a defective filter. I wish he had checked that before installing it. So I drove off after getting new filter installed and couple of miles down the road, a check engine light came on. I went back and he plugged his OBD handheld and determined that a codes P1130, P1135, P0171B and P0125B are coming up. I knew I had O2 sensor problem (P1135 & P1130) in the past and I had gotten that checked and EGR valve cleaned. I did not have check engine light on when I went in for oil change and now it's coming up within couple miles of driving so obviously something went wrong either during oil change or when the defective filter was installed. Mechanic swears it is a right part#. Now he won't do anything about the check engine light because he says those codes were already there. I got the code cleared and took a ride with one of his mechanics and sure enough the check engine light came back. He keeps saying that it has nothing to do with oil change that they did. Also, when he was running diagnostics, he ran the engine up to 4000 rpm while idle and I know you are not supposed to do that especially on automatic vehicles. Does anybody think that a simple oil change could trigger check engine light to come on? I am certain that the other codes that are coming up now, have something to do with the dignostics that he did when it first came on. I am not trying to get a free ride here and all I am saying is the check engine light wasn't coming on when I went for oil change and now it is so I need some explanation on why this could be happening. I am going to get it checked out somewhere else to determine the cause. HELP !!!! :?:
Dec 25, 2006 at 3:45 AM
GARFIELD
  • 197 POSTS
Stop by advance auto parts or autozone and have them pull your codes and let me know what codes are coming up, it may be just a chance that the light came of after the oil change or not, after you get the codes let me know what they are and will try and point you in the right direction. Advance will give you a copy of the codes pulled from the car if you ask to keep the paper that is printed with the machine. Good luck.
Gary
Dec 25, 2006 at 10:24 PM
SERVICE WRITER
  • 9,123 POSTS
I have seen defective oil filter gaskets, and frankly I don't know that it was detectable beforehand. I don't see a relationship of an oil change to the check engine light. I am inclined to think it is a coincidence.
One can go to burger king, leave and the light comes on, but obviously no correlation there.
In this industry, I tend to never paint anything black and white. Anyways, follow Gary's advise and go from there. :)
Dec 26, 2006 at 11:21 AM
BARBARA GILL
I just had my oil changed yesterday on my 2000 Honda Accord V6. I got down the road and my check engine light came on and the car is missing. I went back and they said they couldn't get me in until next week. Can I drive the car or will I get stranded?
Jun 26, 2021 at 2:41 AM
Good morning,
The check engine light and the oil change are not connected at all. Even if the car runs low in oil, it will not set the light.
The shop did nothing wrong to turn on the check engine light at all.
Jun 28, 2021 at 10:20 PM
Good morning Barbara,
No, I would not continue driving it until the issue is diagnosed and repaired. You could cause more issues by driving it with a misfire.
https://www.2carpros.com/articles/check-engine-light-is-it-safe-to-drive
This could be from worn spark plugs, bad coils, or injector issues. All these will need to be checked to confirm the failure.
Jun 28, 2021 at 10:23 PM
BARBARA GILL
I went back to the shop and they got the check engine light off and made an appointment for Thursday for me to come back in. Then I went to go to the store and the car was missing so bad that I went around the block and parked back in the driveway and haven't moved since. I have an appointment Thursday to get it checked. I may have to have it towed. I have dealt with this company for years but recently they got new owners. Now, I'm really worried that I won't get the same service that I had before. Can't afford a new car.
Jun 29, 2021 at 1:53 AM
Clearing the light does nothing.
If it is missing that much, ask them to come and pick it up for you.
Jun 29, 2021 at 4:49 AM
