No start
CARPARTS1
I have a 1994 Toyota camry, 131000 miles. Last year I installed a distributor because of no spark. I recently installed another distributor for no spark, the vehicle would still not start. I checked all fuses, and after a couple of days, I had to charge the battery, vehicle still has no spark. I waited a couple of days, went to the vehicle turned the ignition key and the engine started up, the vehicle ran for 3 days, then went back to the same problem, plenty of fuel, no spark, cranks, no start, can you give me an idea on what to look for? Thank you, Mike.
Nov 11, 2007 at 12:20 AM
MERLIN2021
  • 17,250 POSTS
If engine cranks but wont start, and the check engine light does not operate when the key is first turned on, EFI main relay may be faulty. B+ terminal is located in a small box marked "Diagnosis" under the hood and terminal is listed in box lid.
Nov 11, 2007 at 1:40 AM
