1996 Toyota Camry Speedometer Drops
KGIESE
I have a 1996 camry Le with 165K, last night the check engine light came on and the speedometer would flucuate all over. When driving at hwy speeds it will drop to o MPH and it feels like the transmission is slipping, also it kicks off the cruise control when this happens. I checked the tranny fluid and it seems fine, what could cause this? Almost forgot it is the 4 cyl engine 2200 series.
May 25, 2007 at 1:33 PM
  • 75,988 POSTS
[quote:9d551827b2="kgiese"]I have a 1996 camry Le with 165K, last night the check engine light came on and the speedometer would flucuate all over. When driving at hwy speeds it will drop to o MPH and it feels like the transmission is slipping, also it kicks off the cruise control when this happens. I checked the tranny fluid and it seems fine, what could cause this? Almost forgot it is the 4 cyl engine 2200 series.[/quote:9d551827b2]
Have the vehicle speed sensor check at the tranny, oops! almost forgot there's another one behind the speedo-do the tranny one 1st.
May 25, 2007 at 4:18 PM
Suggested Repair
Check the vehicle speed sensor at the transmission first. If needed, also check the speed sensor behind the speedometer.
Conversation Summary
The owner of a 1996 Toyota Camry LE with a 2.2L four-cylinder reports a check engine light, a speedometer that fluctuates and drops to 0 mph at highway speeds, a sensation of transmission slip, and cruise control disengaging. Transmission fluid appears normal. The expert recommends checking the transmission vehicle speed sensor first, then the sensor behind the speedometer.
