Tire not balanced?
34 MILES • 6 CYL • 4WD • AUTOMATIC
SUNNYSOBA
WHAT IS THE CAUSE OF WHEEL INBALANCES
Nov 6, 2009 at 8:17 PM
  • 31,937 POSTS
Hi there,
Wheel balance problems can stem from faulty tyres, rim problems, or just general wear & tear, the wheel & tyre is a rather heavy rotating force and balance weights are the only way to keep vibration at a minimal, you may have just lost a balance weight, get then rotated and re balanced and this should fix your problem.
Mark (mhpautos)
Nov 6, 2009 at 8:22 PM
