1996 Toyota Camry Cloudy Headlights
RO95GE12R6
Toyota, Camry, '96, 115K, 4cyl, 5spd
Background:
The lenses on the headlights have become clouded. On Lo beam, there is not much light being put on the road. I am under the impression I have sealed beam units on this car and need to replace the whole the thing. For safety reasons, I am ready to do that.
Question:
Is there a way to be sure I am getting lamps that fit my car AND that illuminate the road much better?
Oct 1, 2007 at 8:10 AM
MERLIN2021
  • 17,250 POSTS
I would suspect the MAF before the IAC if the IAC is bad you get rough idle and stalling....
Jul 21, 2007 at 2:03 AM
FISHERMAN
  • 937 POSTS
[quote:3253ad9ce3="ro95ge12r6"]Toyota, Camry, '96, 115K, 4cyl, 5spd
Background:
Question:
Is there a way to be sure I am getting lamps that fit my car AND that illuminate the road much better?[/quote:3253ad9ce3]
Hello!!
well now most of the light units are made out of plastic, that`s why they got clouded ( solar UV )
there its and aftermarket cheap units but they are not as good as the originals.
It`s up to you... and your wallet!
you can try to polish them but after a while they got clouding again!
good luck!
Oct 1, 2007 at 8:18 AM
Suggested Repair
Polish the clouded plastic headlight lenses for a temporary improvement, or replace the assemblies with original-quality units rather than cheap aftermarket lamps for better fit and illumination.
Conversation Summary
The owner of a 1996 Toyota Camry reports clouded headlight lenses and weak low-beam output, and asks how to confirm replacement lamps will fit and light the road better. One reply discusses unrelated idle sensors. The relevant reply explains that plastic lenses cloud from UV, cheap aftermarket units are inferior to originals, and polishing helps only temporarily.
