I have a 96 toyota camry with 70k on it and a 2.2 engine. My car wont start when its humid outside. I live in seattle where humidity is 90% most of the time so this problem is year long problem. It usually takes the second start to start the car. and when it starts it tends to die or stay at very low rpm and shake untill I push some Gas. It start fine in dry weather. No one has been able to figure this out yet. I have just changed the spark plugs and wires, cleaned the injectors, fuel filter, engine coolant sensor but the problem is still there. I even put fuel dryer in the tank thinking there might some water in the tank, but it didnt help. could it be due to MAP? if so how come car drives fine?
Thanks a lot.
Thanks a lot.
Feb 6, 2007 at 8:31 AM
