Failure of Emissions State Inspection
LSELLIER
  • TOYOTA CAMRY
2001 4 cylinder, autmoatic with a 2000 engine from Japan. Odometer-116,000. Engine put in in 2005 had 30,000 miles. I continue to fail the emissions test for my state inspection (Texas). Check engine light will not stay off after clearing codes (after repairs have been made). It returns within 10 miles. Following repairs have been made PRIOR to test.
1. Catalytic Converter (twice in four months)
2. EGR Valve
3. Ignition coils (twice in two months)
4. Ignition wires
5. Spark plugs (twice in one month)
6. Idle adjusted (to correct horrible idling problem)
What am I missing? My mechanic has to call in a mobile diagnostic unit because they can't pinpoint the problem and the check engine light continues to come back. I've spent $1500 trying to fix this problem.
Monday, August 27th, 2007 AT 4:43 PM
Well if you can be kindly enough to give us the OBD2 code/s. We can get you started
Monday, August 27th, 2007 AT 4:56 PM
