1991 Toyota Camry Exhaust Smell
GIANTONE
When I or my wife drive her 91 Toy Camry (115K miles), we reek of exhaust fumes. It passes all exhaust inspections, and no CO is found in the passenger compartment. No exhaust leaks could be detected and when I am driving, I really don't smell the exhaust. It is only evident when I come back to smell the clothes I was wearing or my spouse smells the car fumes on me. The flex pipe on the exhaust was replaced but that did not fix the problem. It uses oil. About 1 qt every 500 or 600 miles city driving. The engine is clean. I reek worse when I have the windows open or use the A/C or heat. When I have the windows up with no A/C or heat running, it isn't as bad. Not sure where to look next. I noticed that when I was idling in traffic for about 20 minutes one day, my car spewed blue/black smoke for about 1/2 mile when traffic started moving and then it disappeared. The engine doesn't seem like it is expelling the fumes or something. Any ideas? I don't want my 1 year old riding in the car cause I don't know how dangerous it is. Thanks for any tips.
Jun 5, 2006 at 2:23 PM
LOSONE
  • 1,616 POSTS
IF you smell it in the car then you have an exhaust leaking from a hole in the exhaiust or bing suscked back inside by the vacuum geberated by the rear area of the car. Smoke when you fist drive is NOT a good sign.
Look at your tail pipe. It must be extended at least 4 inches beyond any obstructions and not installed close to the car. This could be your problem. Buy a short exhaust extension and try it. It may solve your problem.
Good luck
Jun 6, 2006 at 6:01 AM
GIANTONE
Thanks Losone! I'll give your suggestion a try. I appreciate the reply. I'll let you know how it turns out.
G
quote="losone"]IF you smell it in the car then you have an exhaust leaking from a hole in the exhaiust or bing suscked back inside by the vacuum geberated by the rear area of the car. Smoke when you fist drive is NOT a good sign.
Good luck[/quote]
Jun 16, 2006 at 1:03 PM
Suggested Repair
Extend the tailpipe at least 4 inches beyond any obstruction with a short exhaust extension so fumes are not drawn back into the cabin. Also have the oil use and blue/black smoke after idling checked, since that is not a good sign.
Conversation Summary
The owner of a 1991 Toyota Camry with 115,000 miles reports exhaust odor on clothing after driving, worse with windows open or climate control on, despite passing inspections, no cabin CO, no detected leaks, and a replaced flex pipe. The car uses about a quart of oil every 500-600 miles and once emitted blue/black smoke after idling. The expert said cabin odor indicates an exhaust leak or fumes being pulled back by rear vacuum, advised extending the tailpipe at least 4 inches past obstructions with a short extension, and noted the smoke is not a good sign.
