Engine quits at idle or when shiting from Parking
PINO
I had the car (a 2000 Toyota Camry; 4 cylinders)analyzed for problem indicated at subject and I am told (after two days in the shop) that they finally diagnosed to proble to be a bad charcoal canister (?) and because of that gas is bypassing it and getting to some valves. The cost of repair seems outrageous and I even think the problem may be as simple as water in the gas tank since the car was only started a couple of times in over a few months (the car is normaly driven by my wife and she suffered a fractured bone which has kept her from driving since Jan).
May 23, 2006 at 4:12 AM
LOSONE
  • 1,616 POSTS
The canister can cause the problem you describe and they are not cheep.
Don't ever think water in the gas is a simple problem. It can be your worst nightmare. Water isn't compressable and can destroy engine components as well as fuel components.
Good luck
Dec 19, 2019 at 8:11 AM
LREAVES
check your battery....
