Engine Mechanical problem
1994 Toyota Camry 4 cyl Two Wheel Drive Automatic
I need to remove the Crankshaft Pulley so I can get at the timing belt. I've managed to remove the bolt that holds it to the crankshaft but the pulley will not budge. I thought I could pull it off with the Harmonic Balancer Puller but I can't fasten it on to the Pulley to remove it because the bolts that came with the puller don't fit the bolt holes in the pulley. Any ideas? TIA.
Saturday, July 24th, 2010 AT 8:44 PM
