Cooling Fans
DIVA31
  • TOYOTA CAMRY
I have a 1999 Toyota Camry. When I drive the vehicle to the desired temperature in which the fans are suppose to come on they don't. When I turn the air conditioner on I see that they do come on. What could be causing this problem?
Tuesday, May 29th, 2007 AT 3:51 PM
Camry can be a very tricky to deal with, it has about 4 fan relays-start with the coolant temperature sensor/thermal switch-fuses. Could also be the thermostat. And also the computer not activating the relay.
Tuesday, May 29th, 2007 AT 11:09 PM
