The car has two new radiator caps. One near the top of the engine and the other is on top of the radiator.
When hot, my coolant is not overflowing into the overflow coolant container. Oh at least I don't think it is. I cannot find out why I am losing water. When the engine is cold, I see that the upper radiator hose has collapsed / flatten out instead of round.... and the radiator is low on coolant.
I have changed the radiator caps (two different psi) Even changed the radiator with another one because the old one was a bit crooked near the top cap. I also change the tubing going into the overflow unit. Still I cannot determine why the system is not overflowing into the plastic overflow and sucking it back when its cooled down.
is it possible that I have the wrong psi caps ?
Water pump, timing belt, etc. were all changed about 8,000 miles ago.
Why did Toyota install two caps for the cooling system ? And they seem to be different types of caps when you flip them over.
Thanks for any information.
Apr 22, 2006 at 12:42 AM
