Car will not start after purchasing new battery
LAROB611
I have a 1994 Toyota Camry LE, 150,070 miles......the car still will not start after purchasing a new battery......the car does not make any noise after trying to start so i'm not sure if its the starter or the alternator...............HELP!!!!!
Aug 31, 2006 at 9:07 AM
SYNCRAIT
  • 235 POSTS
what was the problem before you changed the battery? when you turn the key to acc does the radio turn on? if it does then i would have your starter relay looked at but if you simply hear sometime very faint clicking sound replace the starter...... It wont have anything to do with your alternator because that is only used once the car is started..... good luck lemme know :)
Aug 31, 2006 at 1:36 PM
