1999 Toyota Camry Running Hot
DIVA31
I have a 1999 115,311 miles 4 cylinder Toyota Camry and it is running hot. I checked for water in the radiator and it is full. When i drive the needle goes up but not quite into the red. When I turn a corner the guage goes back down. What else can I do or repair to stop my car from running hot?
May 26, 2007 at 1:36 PM
  • 75,988 POSTS
[quote:eb6370925d="diva31"]I have a 1999 115,311 miles 4 cylinder Toyota Camry and it is running hot. I checked for water in the radiator and it is full. When i drive the needle goes up but not quite into the red. When I turn a corner the guage goes back down. What else can I do or repair to stop my car from running hot?[/quote:eb6370925d]
Cheap fix change the thermostat for a start
May 26, 2007 at 2:07 PM
Suggested Repair
Start with an inexpensive thermostat replacement.
Conversation Summary
The owner of a 1999 four-cylinder Toyota Camry with 115,311 miles says the engine runs hot while driving. The radiator is full, the gauge rises but does not quite reach the red, and it drops when turning a corner. An expert recommends replacing the thermostat as a cheap first step.
