Burnt/Pitted Valve Stem
CARTECH_SAVVY
  • 8 POSTS
Howdy!
I got a v6 Camry engine and I've noticed that the right hand side exhaust valves (all 6 of them, by equal measure) are showing signs of pitting/erosion on the valve stems. Anybody know why this would happen to the right hand bank only?
Also, if the burn-off isn't severe, is it still safe to re-use the valves for a couple more years? I have a 92 with more than 120K miles on it, I'd hate to spend on new valves if something else in the block is gonna call for some major work just a few more miles down the road. I don't drive the car hard anyways, so unless I purposely set the timing late, the valves should hold up for a while.
Thanks for your advice!
Sep 20, 2006 at 4:26 PM
CARTECH_SAVVY
  • 8 POSTS
Anybody here who might be able to give me the cons in reusing exhaust valves with [b:72c6bb93c9]slightly eroded[/b:72c6bb93c9] valve stems--that is, other than the obvious reason that they've got fewer miles of life left in them already?
Sep 26, 2006 at 7:21 AM
