2001 Toyota Camry Gas Pedal Sticks
BOWERS2001C
I have owned my 2001 Toyota Camry for 1 1/2 years,
it has 109,000 miles on it and runs great, but about a month ago every once in a while at stoplights when I go to accelerate the gas pedal sticks and I have to really stomp it to get it to move, then it runs fine. I have noticed it is worse on the colder mornings.
Is this something that will be hard/a major repair?
Dec 16, 2006 at 3:52 AM
CARUNDELL
  • 602 POSTS
[quote:65db5c4eb3="Bowers2001C"]I have owned my 2001 Toyota Camry for 1 1/2 years,
Is this something that will be hard/a major repair?[/quote:65db5c4eb3]
Hey bowers,
Sounds like the throttle plate my be full of carbon and sticking. Simple fix is to remove the air duct at the throttle body, open the throttle by hand and spray carb cleaner (a bunch) and with a small wire brush clean away all the carbon deposits on the bore and the throttle plate. you may have to spray several times to get it clean. Also, it may pop a misfire code when you start it up (will need to be cleared) as it will run rough for a bit and it will smoke a little too. Let us know!
Chris
Dec 16, 2006 at 3:58 AM
Suggested Repair
Clean carbon deposits from the throttle body bore and throttle plate. Remove the air duct, open the throttle by hand, spray carburetor cleaner, and scrub with a small wire brush. Repeat until clean. Expect brief rough running, light smoke, and a possible misfire code that may need to be cleared.
Conversation Summary
The owner of a 2001 Toyota Camry with 109,000 miles reports that the accelerator occasionally sticks at stoplights and must be pressed hard to move, then runs normally. It is worse on cold mornings. The expert says the throttle plate is likely sticking from carbon buildup and recommends cleaning the throttle bore and plate with carburetor cleaner and a small wire brush. The engine may run rough, smoke briefly, and set a misfire code that needs clearing.
