A/C Heater Fan
DMCENTYRE
I own a 99 Toyota Camry LE with the 2.2L engine and 160,000 plus miles. For over a year my climate control fan would only work on medium or high. While driving down the road yesterday, the medium stopped blowing. I switched to high and it worked fine. What is my problem? Blower motor, fan, switch, relay, resistor, etc.?
Oct 1, 2007 at 3:48 AM
FISHERMAN
  • 937 POSTS
[quote:9ea29618d3="dmcentyre"]I own a 99 Toyota Camry LE with the 2.2L engine and 160,000 plus miles. For over a year my climate control fan would only work on medium or high. While driving down the road yesterday, the medium stopped blowing. I switched to high and it worked fine. What is my problem? Blower motor, fan, switch, relay, resistor, etc.?[/quote:9ea29618d3]
Check The blower resistor....
It should be located in the air ducting under the glove compartment,the glove compartment may have to be removed to find it, it's attached with either one or two small screws and has an electrical connector with a bunch of wires.
Let Us Know!
Oct 1, 2007 at 9:15 AM
