1999 Toyota Camry P0446 EVAP Code
RAHMZZ
scanner pulled code po446/evaporative emission control system vent control circut malfuntion.
i can clear the code but the check engine light will
pop back on in a day or two.the car starts/runs fine
whether light is on or off. the car has 105,000 miles
would appreciate any advice as to where to
start checking as far as repair.
thanx ted
Sep 3, 2007 at 12:33 PM
  • 75,988 POSTS
[quote:e09dbc842b="rahmzz"]scanner pulled code po446/evaporative emission control system vent control circut malfuntion.
thanx ted[/quote:e09dbc842b]
Could be a loose gas cap, vacuum line disconnected from gas tank, saturated charcoal canister, venting solenoid or wiring problems to it.
If this code continues to comeback the dealer has the special procedures to eliminate this code.
Sep 3, 2007 at 10:45 PM
Suggested Repair
Check for a loose gas cap, a disconnected vacuum line at the fuel tank, a saturated charcoal canister, and a faulty vent solenoid or wiring. If P0446 returns, have a dealer run the special diagnostic procedures for this code.
Conversation Summary
The owner of a 1999 Toyota Camry with 105,000 miles reports a recurring P0446 evaporative emission vent control circuit code. The check engine light returns a day or two after clearing, but the car starts and runs normally. The expert suggests checking the gas cap, tank vacuum lines, charcoal canister, vent solenoid, and related wiring, and notes that a dealer has special procedures if the code continues.
