When I turn on my AC Switch inside the car, the compressor does not turn on.
Apr 2, 2007 at 9:58 AM
BOOTDOG
✓Experienced Mechanic
you're probably low on freon. but you can bypass the high and low pressure switches with a paper clip to rule them out if they're ok. if the compressor cuts on when you bypass the switches then replace which ever switch is bad.
