I have a 1989 Toyota Camry that has 270,000 miles on it and when turning either way the whole car clunks. I first thought that it was the CV joints/Axles so I replaced both sides with the whole assembly.
I have found out that this did not fix the problem. I still have the clunking turning both ways when taking off. It still acts as the axles are put in a bind in some way and knocking. I have noticed the bushings that attach the sway bar to the lower control arms are both shot and wore bad. Can this be the problem. If so where can I get a new set of bushing instead of purchasing new control arms. Thanks
Feb 28, 2007 at 4:58 AM
