89 Camry"No Oil Pressure"
HOP250R
  • 1989 TOYOTA CAMRY
I took on a 1989 Toyota Camry with a 2000 4 cylinder and an automatic. It was a one owner car with 140,000 on the odometer. When the oil light came on he took it to a nearby shop and was told he had lost oil pressure. I believe I confirmed this for him by pulling the oil filter off and starting the engine. Absolutely no oil came out from the filter port. Is it safe to say I should be looking at a possible oil pump failure or if I'm lucky a pickup that has fallen to the bottom of the oil pan? Thanks for your time.
Monday, November 19th, 2007 AT 7:04 AM
Pulling the oil filter off and starting the engine. Absolutely no oil came out from the filter port. Is it safe to say I should be looking at a possible oil pump failure or if I'm lucky a pickup that has fallen to the bottom of the oil pan? You could be positively right but to actually check it use a mechanical oil pressure gauge to confirm.
Monday, November 19th, 2007 AT 2:30 PM
