2007 Toyota Camry wheel bearing
12,000 MILES • 4 CYL • FWD • AUTOMATIC
GMANUSC2001
can a wheel bearing be replaced without needing to replace the existing hub?...ie proper removal of bearing without damaging the hub...and is this recomemded by most manufacturers?
Jun 27, 2008 at 9:48 AM
MERLIN2021
  • 17,250 POSTS
If the bearing did not sieze onto the sub-hub yes you can. If the bearing surface of the sub-hub is heat damaged or pitted, it should be replaced.
Jun 27, 2008 at 10:13 AM
