2007 Toyota Camry security alarm
48,000 MILES • 4 CYL • FWD • AUTOMATIC
NEAL HENDRIGSMAN
  • 9 POSTS
While I am driving an alarm will sound and a message will show on the message center that says the hood is open when it is not. When I park the car and lock the doors several hours later the security alarm will go off, this may happen several time during the night.
Can you help me solve this problem?
Nov 11, 2009 at 5:23 AM
KHLOW2008
  • 41,812 POSTS
Hi Neal,
Thank you for the donation.
The hood switch is out of adjustment and when there are any vibration or body shear of the hood, the switch would come into contact as if the hood has not been closed correctly. This condition would also cause the alarm to be triggered intermittently.
Check the hood switch adjustment and stopper.
Nov 11, 2009 at 6:05 AM
NEAL HENDRIGSMAN
  • 9 POSTS
Where is the the hood switch located?
Nov 11, 2009 at 11:42 AM
NEAL HENDRIGSMAN
  • 9 POSTS
Can you tell me where the hood switch and stopper are located? Can I get to them without special tools?
Thank you,
Neal
Nov 12, 2009 at 9:28 PM
KHLOW2008
  • 41,812 POSTS
Sorry for the delay in replying.
I am not sure of the exact location of the hood switch for your model but it should be visible if you open the hood and check the panel, most likely near the headlights.
No special tools are required but a screw driver and/or plier would be required to adjust it.
Check if the hood switch bracket is bent too far away and not allowing the switch to be closed fully when hood is locked..
Nov 15, 2009 at 12:01 AM
NEAL HENDRIGSMAN
  • 9 POSTS
I don't quite understand what you mean by the panel. What is the panel?
Neal
Nov 16, 2009 at 3:19 PM
KHLOW2008
  • 41,812 POSTS
Sorry if I did not make myself clear.
Panel means the upper support frame around the radiator and headlights, along the perimeter of the engine compartment.
Nov 17, 2009 at 3:00 AM
