2007 Toyota Camry Road Noise
VOLLJR
Tires and Wheels problem
2007 Toyota Camry 4 cyl Front Wheel Drive Automatic
I have been hearing a lot of road noise coming from the right rear side. I had the car in to a tire store because that tire had a small leak. I ask them about the noise. They told me that the tire is cupped due to:
Not rotating tires
worn struts
My question is whether either of those could be the problem or could it also be a problem with the tires. They also told that the other rear tire was cupped as well but not as bad as the right
Nov 27, 2009 at 12:58 AM
KHLOW2008
  • 41,812 POSTS
Hi Volljr,
Apart from those mentioned, worn arm bushes, rear wheel alignment and tires can cause the problem.
Nov 28, 2009 at 12:29 AM
