Tires and Wheels problem
2007 Toyota Camry 4 cyl Front Wheel Drive Automatic
I have been hearing a lot of road noise coming from the right rear side. I had the car in to a tire store because that tire had a small leak. I ask them about the noise. They told me that the tire is cupped due to:
Not rotating tires
worn struts
My question is whether either of those could be the problem or could it also be a problem with the tires. They also told that the other rear tire was cupped as well but not as bad as the right
Not rotating tires
worn struts
Nov 27, 2009 at 8:58 AM
