2007 Toyota Camry repairing
2007 TOYOTA CAMRY
ELSAYED
Transmission problem
2007 Toyota Camry 4 cyl Two Wheel Drive Automatic
i have problem in gear box and
1- I repair it and it not good as it harsh in all shifting.
2- I replace it by scond used gear at first it good and the range switch not good i replace it and adjusted the cable the car some times good and return to harshing in all shifting what can i do.
Nov 3, 2008 at 5:14 PM
SERVICE WRITER
  • 9,123 POSTS
Are there any codes in the computer?
Are the connectors on tight and pins not bent that goes to the tranny?
Check inputs, throttle position sensor and VSS for proper ohm readings.
Nov 3, 2008 at 9:58 PM
