2007 Toyota Camry Outside Temperature Sensor Responding Very slow
44,000 MILES • 6 CYL • FWD • AUTOMATIC
RKOESTER
The outside tempurature display takes more than an hour to adjust to changes. For instance, parked in the garage in the morning, it shows 63 degrees. Even while driving in 85 degree weather, it will show 63 or 64 degrees for at least an hour. After I park it for several hours and return, it will indicate the current temperature but then again changes very slowly. Is there a way to clean the sensor? If so, where is it located and how do I do so?
Thanks, Ron
Jun 9, 2008 at 3:44 AM
KHLOW2008
  • 41,812 POSTS
Hi rkoester,
I am not sure about the exact location but it should be somewhere along the front lower portion of the bumper.
If it is caked with mud, then it is possible to clean it.
Jun 9, 2008 at 4:40 AM
