2007 Toyota Camry OBD codes
2007 TOYOTA CAMRY
62,000 MILES • 6 CYL • 2WD • AUTOMATIC
MICPNJ
I have pulled two codes P0057 and C1201 from the computer but cant find what the issue is and what repairs would need to be. Are these quick fixes or expensive repairs
Jul 22, 2009 at 4:19 AM
BUDDYCRAIGG
  • 2,262 POSTS
What sub model of camery do you have? Like CE or XLE?
I don't show those as being possible codes for your car.
the P code is going to be something to do with engine performance.
the C code is going to be something to do with the chassis, like ABS or traction control.
Jul 22, 2009 at 1:32 PM
MICPNJ
It is an XLE
Jul 23, 2009 at 1:51 AM
STEVEW84
  • 673 POSTS
DTC P0057 Oxygen Sensor Heater Control Circuit Low (Bank 2 Sensor 2)
The C1201 code has to do with there being a code inthe PCM. Fix the p0057 first then see what happens. Its most likely a bad oxygen sensor. Make sure you get an OE from the dealer.
Jul 23, 2009 at 4:15 AM
BUDDYCRAIGG
  • 2,262 POSTS
Although I still dont show the P0057 being an option on my list for your year, the generic standard is it's Powertrain:HO2S Heater Control Circuit Low Bank 2 Sensor 2
and the C1201 shows to be
Toyota: Brake Boost Sensor Circuit Range/Performance.
But as stevew84 said, it may go away after you fix the powertrain problem.
Jul 23, 2009 at 11:34 AM
