2007 Toyota Camry Grinding Started
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
WQUINN
when starting a cold engine that has been sitting overnight, a grinding noise will occur and then the engine starts. This noise does not happen when the engine is warmed, shut off and then restarted a few minutes later. This only happens when the vehicle has sat for several hours. The vehicle is a 2007 toyota camry with 10,000 miles.
Dec 16, 2008 at 12:03 PM
  • 75,988 POSTS
This grinding noise is it coming from the starter or somewhere else-if its from the starter could be that the starter is too far from the flexplate-try torquing the starter bolt and see what happens- if its some where else you need to pinpoint it and get asap
Dec 16, 2008 at 2:29 PM
