2006 Toyota Camry Small 3-4 vibrations when brakes were app
54,000 MILES • 4 CYL • FWD • AUTOMATIC
SENAPATHI007
I have 2006 Toyota Camry SE. Its mileage was 54,000. When I apply brakes on normal road, most of the time, it is normal stop. But, when I apply complete brakes slowly on snow and salty area, the car is giving small 3-4 vibrations. What is the reason for those jerks. Somebody told me that it is mainly due to anti-lock system brakes (ABS), where wheels won't stop quickly and will lock at different pressures and times. Please answer to the above problem of vibrations after hard brakes.
Feb 16, 2010 at 4:55 AM
MY72IHC
definatly the antilock brakes if it doesnt do it in dry or slightly wet situations when on snow and ice each wheel requires diffrent pressures to grip the road and give you the quickest stop possible without locking up the wheels. if you do get the vibirations in dry conditions you might consider getting the rotors turned
Feb 19, 2010 at 4:24 AM
