2006 Toyota Camry How to replace the Fuel Filter
200,000 MILES • 4 CYL • FWD • MANUAL
MH.MUGHAL
I am living in Saudi Arabia-Jeddah, having 2006 Camry.
It started some unusual small Pauses / jerks during the low speed. Took to the mechanic who advised to bring the Fuel Filter and will change it. I believe it should be something very difficult sp i decided to check with you whether i can do it or not. By the way i am an electrical Engineer and most of the mechanical tools and instruments are not unknown to me. Please guide me and i am sure i can do it easily.
Regards
Manzoor H. mughal
Saudi Arabia - Jeddah
Aug 23, 2010 at 9:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove or disconnect the following:
Negative battery cable.
On vehicles equipped with an air bag, wait at least 90 seconds before proceeding
Protective shield for the fuel filter
If necessary, air cleaner hose and cap
If necessary, charcoal canister.
Slowly loosen the lower flare nut fitting until all the pressure is relieved
Banjo fitting and 2 metal gaskets.
Discard the gaskets
Fuel line with the flared nut from the filter
Filter from the mounting bracket
To install:
Install or connect the following:
New fuel filter
Banjo fitting with a new metal gasket on each side and install the union bolt. Bolt: 22 ft. lbs. (30 Nm). Flare nut to the lower connection. Nut: 22 ft. lbs. (30 Nm).
Charcoal canister
Air cleaner hose and cap
Protective shield
Apr 6, 2019 at 11:08 AM
