2006 Toyota Camry Charging System
2006 TOYOTA CAMRY
64,000 MILES • 6 CYL • FWD • AUTOMATIC
MDEGRAAF
What should the Voltage Regulator output be. I am getting only 12.77 volts.
Sep 17, 2008 at 2:24 PM
Get your alternator and battery load tested-12.7 volts is just the open voltage of the battery before you start the car. It should be at the range of 13.5-14.50 volts running-
Sep 17, 2008 at 2:35 PM
