2005 Toyota Camry vibration sound
2005 TOYOTA CAMRY
69,000 MILES • 4 CYL • FWD • AUTOMATIC
CARCAMRY
When i switch on the car and start accelerating the car slowly i can listen to a vibrating noise (its like a metal thin rod shaterring) beneath the car just 1/2 second and than its fine.
I wanted to know what is this sound. I have not heard this before.
Regards
Nov 26, 2009 at 7:19 AM
  • 31,937 POSTS
Hi there, i would start with having the exhaust heat shields check.
Mark (mhpautos)
Nov 26, 2009 at 7:54 AM
CARCAMRY
The dealership verified and said its Cat problem and they replace it, after which still it i can listen to the vibration. According to the technician its the Abs actuator which is normal it makes this sound but i am not convinced with it as it never use to make this sound earlier. I will ask them to check the heat shield as well. Any other suggestion or any one have faced this problem.
Nov 27, 2009 at 12:30 AM
